Plan on building 2 mightyrams, the ram50 is going to be a
4g63t mated to a th350.
When I find a MM it's going to get a 2.4 destroked to a 2.1 with the b2600 bellhouseing and FC rx7 trans. But first things first HI!!!! Glad to join the group!!!
Hi and welcome to mightyram. Adding a bit of Mazda into the mix? Interesting idea - the RX7 trans is a tried and true mod. What reciprocating parts are you going to use to destroke the 4G64? Looks like you have done some research into your build plan. :)
Welcome......interesting........got pics?
Hope you post this build here.
88mm crank with 156mm rods, Manley makes a complete 2.1 destroker set. But I haven't decided if that's what I'll go with. I'll keep it all posted up. I wanted a trans that would shift at 10,000rpms and I know that those rotary motors did that and that those transmissions where meant for it. I'll probably run a 2g head with a light valve terrain. But it'll all come in time.
My phone won't let me upload the picture I have. Its still sitting at my friends house where I had to park.
You can get and use the app called ForumRunner
It works good. There is also a native board app. Clear the cash on your phone and the first time you access the board with the phone it will ask you if you want to use it. But you do get some limitations with the app.
