No Balance Shaft Sprocket=Balance Shaft Elimination Kit?
Looks like the Balance Shaft at sometime and the RH Balance Shaft Sprocket is rounded out. Searches for part (MD041401) turn up nothing. Balance Shaft flat has some rounding and can find a balance shaft (MN137236). So....option is to delete balance shaft without if I cant get a sprocket.
Have on order multiple parts on order that list as Mitsubishi Parts numbers, however, show up on compatibility as newer 4G63's.
Anyone have experience with compatibility of these parts with G63B?
Snub Shaft MD098626
SPACER, MD092785
PLUG, MD092785
Was in the middle of a rebuild and already have Front and Rear Balance Shaft Bearings.
Ok...will these parts match up with my old G62B.
1987 DODGE RAM 50, VIN:JB7FL24D9HPO14735, 2.0, G63B. BASE, MANUAL 5 SPEED, 2WD.
Thanks
