It sounds like timing. The timing light shows when spark occurs with relation to crank position. If all the ignition wires are properly connected and in the correct firing order, and you can't keep it idling at 7-10 degrees advance, my guess would be you have a valve timing issue. Being one tooth off on the timing belt might be the cause.
