good to know
i figured this out today, the crank position sensor and ignition control module wiring ties in together and then branches off and connect at pin 1 and pin 6 at the ecu. when i test for resistance between the icm and pin 1 the resistance is 1.7 ohms. but when tested from the icm to pin 6 its at .3 ohms. the when i test from the cps to pin 1 its at .3 then from that to pin 6 its at 1.3. so is there a resistor somewhere in the wiring in between there (the haynes manual didnt show one neither did the fsm from mitsubishilinks.com) or is that a good place to look for a short.
