Originally Posted by
geezer101
If you've got oil pressure issues, fragged bearings aren't going to help. This is one of those things where you won't know how bad it is until you've done a visual inspection and then it will be on you on the course of action. A big end or main journal bearing failure can cause catastrophic damage to the crank and/or rods. I think the oiling issues that plagued earlier 4G63 engines weren't an issue once they changed the head design, but it's still an engine. Change rings and hone the bores? - maybe. Bottom end bearings and crank inspection? - yeah, I personally would...and throw some new seals in it front and rear.
