also notice the grind was for duration, not for lift. There is a max lift on these motors that if exceeded, gain you nothing. On the 2.6, you can get valves that are swirl polished and reduced stem at the valve head for better flow as well as a larger head. not sure if the 2.4 has valves like that available.
