No, the 4g54 rods are not the same and will not work in a 4g63. Here's the part number for the rods you want MD040550.
If you're comfortable with Ali express, you can order the rods here.
https://m.aliexpress.com/s/item/3281...70bc08b9qKHKF5
Nice! Thanks!
beware - those are Chinese rods...
Aren't they all?
The original ones are Japanese. there are forged ones made in the USA, but they are pricey
I don't suppose there's an easy way to tell?
Hi again. I haven't abandoned this thread, I've just been dealing with a *hitstorm of other stuff lately.
The other day I got back into this. Pulled the tranny and pulled the engine. Then I got started on disassembly.
The cylinders look pretty good. Crosshatch is still there in all 4 and no ridge. The oil pan had no debris in it.
I pulled pistons 1 and 2 and the rod bearings looked really good. I was beginning to think the *hitstorm was over. But I pulled the #3 cap and it didn't look so good. The bearing was "groovy" and the journal had a little too. So I pulled the rest and they were all about the same. After I got the crankshaft out I took it to a recommended shop and he says its just too far gone for a polish. But his cost for regrinding is as much as a rebuilt one that comes with bearings.
So what's the opinion here? Grind the OEM or get the rebuilt kit from RA?
I was also looking at a rebuild kit from DNJ that includes pistons, rings, and all the gaskets (no crank). Any opinions on them?
