Many thanks to GEEZER. I set up my 32/36 Weber on 2.0 G63B with Australian headers using his jet settings.
As we say in Texas, "It's running like a lizard on a hardwood floor"!! Great power, smooth and getting much improved gas mileage.
ElSupremo
Good to hear elsupremo. I pulled the jetting data from the 'WEBER CARBURETORS' bible by Pat Braden. It's an excellent resource manual and it contained a ready chart for the set up most commonly referred to for an upgrade on mightyram. What sort of improvement are you getting on your MPG?
I ran the carb for almost a year using the jets that came with it. On the one long trip that I took staying at 55-60 MPH for about 350 miles each way I got a little over 29 MPG. Daily driving averaged 23-24 MPG. This is using regular pump gas containing ethanol.
I have yet to change the secondary emulsion tube from F50 to F66 and the primary idle jet from .60 to .50. With the other new jetting I have gotten a little over 27 average. That leads me to believe that I might get over 30MPG on a 55-60 MPH long trip. I have access to pure regular gas and might try some later just to see how much more improvement I can get with it.
The thing to remember with E10 gas is that the ethanol leans out the mixture, requiring more fuel to compensate. If you run non ethanol fuel, it may run rich or be perfect. I am interested in your results, as I have the 86 project truck to get running again with a weber conversion.
You might find changing the emulsion tubes will have very little impact on performance. I would be tempted to say your current set up is close to perfect (if it is running the tiniest bit on the rich side it would be safe to leave it there in case you get into hills/mountains, towing a load or getting a tank of crap fuel). Using 97+ might not yield any big improvements on MPG but it'll run crazy smooth on it once you've tuned the engine to make the most of it.
Okay i was about to order the jets online, but i just wanted to be sure i get the correct ones.
Main jet - (primary throat) 1.35
(secondary throat) 1.30
Air Correction - (primary throat) 1.75
(secondary throat) 1.45
Those are what are recommended. However on the website the sizes are listed as .130, .135 ect. Not sure if i just ignore the decimals not being in the same place or if i need to convert from one unit to another to get the correct size. Anyone know?
Looks like they just screwed up the decimal place. They are using cm to convert (which is stupid of them not to identify those as the measured units) .13 cm = 1.3mm
The jet sizes are correct Mischif, so order to your hearts' content and get motoring! :layrubber:
Jets came in today!!! Just finished putting them in and readjusting the idle mixture, idle speed, and then mixture again. A little surprised at how much adjusting i had to do. With the old jets with everything dialed in i was getting 18ish" of vacuum, with the new jetting and everything adjusted im sitting just about at 20" of vacuum now. I replaced both air correction and main jets. I had ordered an idle jet to replace the .60 i have on the primary side but i ordered the wrong style :(. My weber uses the big style idle jet on the primary and then the small style on the secondary. Oh well i'm gonna drive it around for a bit and then decided if i want to go ahead and get the right idle primary or not.
Gonna go cruise and see what kind of difference i can tell.
Anyone know why it lists two sets of air jets?
Thanks
