Nice. Now top it off with a wood shift knob and a wood suicide knob.
Just in case you ever wondered how they make a steering wheel.
http://www.youtube.com/watch?v=rp7RdQ9YgG8
BWWWWWAAAAAHAHAHAHAHAHAHAHHAHAHAHAHAHAHAHAHA. It is always good to see how a high end product goes through it's R & D phase before it finally makes it into production - and into a Honda. I don't know what was worse - the actual routing and cutting out or that freaking narration...
Wonder if Grant started this way. :rolleyes:
Same as stock....but found out later you can buy different thickness spacers depending how far out you the wheel offset and eliminate the quick release hub part . So yes just buy the short hub horn adapter and a wheel, then determine how far out you want the wheel to be, then look for a 6 bolt spacer.
