Danger, Danger - they're multiplying!!
Those are just baby's, Here's papa............
http://i56.photobucket.com/albums/g1...cture006-3.jpg
lol its a T101
Interesting. The options that are availible for the fuel injected guys. Lol. Evo x turbo is twin scroll and reversed flow compared to the 20g and 12a. Ecuflash so 2gb ecu or evo 8 ecu?
The evo 10 not reverse rotation evo 4-9 is reverse rotation, I will use a h8 ecu out of a 2001 eclipse or dodge stratus with the 2.4 and use the evo rom. I have a 106 mm turbo, but that's for another project
http://imageshack.us/a/img692/4983/ls78.jpg
Looking real good there Mr.
How much work is it to convert an 89' mighty to EFI? I want to throw a turbo on my 89' mighty and it seems the toughest part is working out this little dillemma. Any advice or recommendations fellas??
If you can get the complete harness from the ecu to engine, along with the intake manifold
Loves it. This is what I want to do exactly. How you dids it? It bolted on, moved the TB to the other side?
you gave me the idea, I had the TB moved to the other side
well allright! What motor was the galant mani taken from ? I want to check some yards for the same one.
that end for end swap is a common mod for the starquest magna intake swap
87-91 galant, pennyman1 i did the same thing on my conquest but i had a DOHC 4g63 instead of a g54b
http://img138.imageshack.us/img138/5793/gopr0121.jpg
1 Attachment(s)
Nice to see it's not just my garage that needs a good going through.
Last time I cleaned out my garage I found an extra turbine laying in the back.
Attachment 7208
My my, i love it more and more. I want to see how you route the throttle cable, im searching for a manifold now. I want all my intake on the right side where the battery is now, will look so much cleaner.
1 Attachment(s)
For the throttle cable on mine, I just flipped the mount to point to the fender...over the brake reservoir, around to the front...
Attachment 7268
I was thinking of doing that,thanks for the posting the picture
Galant upper sohc 90-92? Correct? I cant find pics of it exactly. Found bunch in yards that are not near me to go and see.
If I find some i will let you know
How are you going to manage the Fuel Injection?
