oil filter, fuel filter, air filter, oil, front shocks, fan clutch, replaced the leaking oil pressure line on the block, thermostat, egr valve cleaned, plugs, wires, rotor cap, distributor cap, radiator flushed, replaced the radiator cap, idler arm. Still rough idle(I know some of thoes things wont help the idle but i wanted to brag) what eles can i check before I do the carb????
