Getting hard into the panel reproduction game.
Bought a 20 ton press not long ago and have been thinking about how to reproduce these cab mounts/floor panels. It sure is nice to have the radio going and use my metal shear and press rather than endless grinders and hammering dulling my ears to the outside world.
Attachment 24808
So we start with our rusted out, but largely in shape cab mount.
I picked it apart and took some measurements. Can gladly confirm the dimple die I made prior is a perfect match
Attachment 24809
Attachment 24810
I pin some sheet metal between two ply bucks and use the die and about 6 ton of pressure to make the dimple.
Attachment 24811
The metal ends up a bit stretched, but a few go rounds with a planishing hammer shrinks those down
Attachment 24812
I can then check to see if I'm making the right depth
Attachment 24813
I can then trim the floor panel to size (edges oversize for final fit, cab rear overhang and inner sill flange cut to size, overhang bent)
Attachment 24814
I found that if I used a steel plate with a matching sized hole in it I could get a nicer crisp edge on the dimple, so I used that on the next piece and the floor piece at the same time to make sure the dimples are the same shape and depth. In the future I will press two panels at once.
Attachment 24815
I also fitted a tubing offcut to punch out the bolt hole dead centre.
Learning for next time
Attachment 24816
Attachment 24817
Nice fit between all the panels.
Luckily the passenger side was in better shape than the driver's, so I was able to get some good measurements and a better idea of the shape details. Like the kick in the upper strengthening plate at the B pillar.
So I marked and cut out the upper plate
Attachment 24818
Attachment 24819
I opted to cut and weld to get the kick this time, I'm short on steel stock. It doesn't take much time but I could also make something to press it in.
I radiused the corner and welded the cab back corner and hammered in the raised bead (I will probably make a tool to press this in next time, it would be quite basic and take 30 seconds instead of 5 mins)
Attachment 24820
And the panels fitted together
Attachment 24821
