Please Look:
https://youtu.be/4_EFGAFxi1w?feature=shared
https://youtu.be/tGeZQUHzGrg?feature=shared
coil wire to dist cap connection MUST be very snug..!
If misfire continues after doing the above tests THEN (I WOULD) buy a new distributor cap & rotor..
I sprayed electronic cleaner into my distributor then dried with gentle compressed air...
Last might be the gapped IC chip in the distributor...
Must check ignition timing INITIAL VACUUM & CENTRIFIGAL
Good Luck finding the cause of misfire :thumbup:
