https://youtu.be/8ca08TIcVVs
Is this a sign the pump need replacing, or is it something else? Tensions were checked and I also took of the belts and inspected them.
you sure that belt is tight? if so than the pump needs replacing. also, be sure its the right v-belt. it looks like a loose belt to me.
Before you replace the pump, just try out that new belt you got. Could be the old belt looks fine but is actually worn/glazed/hardened/etc. from age enough to impair its traction against the pulley.
Appreciate the suggestion. It turned out that although the belt was in good condition the tensioner was maxed out and the belt couldn't be tightened anymore. After trying three more shorter belts, I found the correct length and there is no more issue. I will be sending the pump back and using the money for other parts.
Thank you!
