1988 Mighty Max 2.0 California Version Looses Power/Engine Bogs Out on Freeway
The Problem > It will start and run, rev and idle (after warm up) with no issues. It will drive ok at low city speeds for about 20 min. Taking it on the freeway, it will act like it run out of gas. Sometimes the engine dies outright but it will be able to start right back up. Other times I am able to keep it running by holding in the clutch and revving the engine or just putting in the clutch and the motor will idle but bog out if you give it gas. After about 1-5 min of this, it will start to drive ok at low city speeds for 15 or so min then will start to die out anyway.
Work done to try to fix this issue (and other repairs as needed)
·         Rebuild the carb
·         Replaced Cap, Rotor, Spark Plugs and Wires
·         Replaced the Fuel Pump
·         Replaced all/most vacuum hoses (there could be a hidden one I missed)
·         Found the EGR valve stuck ½ open and cleaned it so it is working
·         Found the gas tank had a pressure leak around where the gas gauge bolts on and made new gaskets
·         Cleaned the gas tank to make sure it does not have debris in it
·         Replaced the gas cap
·         Replaced all the gas lines and replaced the fuel filter
·         Found a wire running from the coil to the heat sink on the coil that has a few strands left and replaced it.
·         Replaced the coil and heatsink
·         Checked the distributor vacuum advance, they both move when a vacuum is pulled on them
·         Removed and checked the electronics of the distributor and made sure it was in spec on the multimeter
·         Checked/cleaned the PCB valve
·         Replaced the Alternator
·         Checked the electronic choke and it is moving and locking open when everything it warmed up
·         Replaced the Oxygen Sensor
·         Replaced the water pump (started leaking)
·         Replaced both timing belts (I was in there anyway)
·         Replaced the Catalytic Converter
