Original Seal Brand Question
I noticed that the tailshaft seal was an "NOK AE8378E0" part number. I thought that it was an "NGK" because I never heard of NOK before. Does anyone know if that is the OEM seal? I am assuming so, because I can only find it internationally.
I found the correct OEM part number and O'Reilleys has a replacement locally in stock. I'm just curious if the seal was original. It seems all the rubber is no longer holding up, so I should probably replace everything important if I want to keep it from leaking.
Thanks,
Chris
