1990 Mighty Max 2.4L- covert from fuel injection to weber carburetor??? Possible???
I bought the truck for my son as his first truck...thinking we could get it going as a father-son project. It's been a nightmare with this fuel injection. The truck originally would start- run rough and begin to smoke. The guy I bought it from and I both thought it was probably the valve seals. The compression is great at about 158-162 across all 4 cylinders. My son and I pulled the head and rebuilt it anyway, cleaned the injectors, replaced the timing belts (taking care to use the notch and not the head-block seal as the reference for timing the camshaft), and water pump. Compression still about the same. Replaced the O2 sensor. Completed a full tune up. Set the timing by grounding the wire by the firewall. It doesn't smoke much now, but still runs very rough as before most of the time, however a few times, it has started and run very well. Eventually, it returns to poor idle and power.
After examining the freshly fouled plugs, I am fairly confident that the truck was just running rich rather than burning oil (rebuilt the head unnecessarily) and something was wrong with the fuel injection.
So, we the checked the ecu which was a rebuilt unit and replaced one capacitor- didn't help, then I bought a new rebuilt ecu from rock auto- no change. Bought a new distributor without improvement because I thought the crankshaft sensor might be bad-nope. Replaced the fuel pump and filter- nothing (checked the fuel pressure and it's in spec).
Finally, I unplugged the MAF sensor and the truck runs much better but still not smooth and has low power. So, I bought a reman MAF sensor- nope... runs way worse with it.
I'm guessing there must be a ground issue somewhere or I've got a bad injector (but they all tested great). I've wasted a can of starter fluid looking for a vacuum leak. I checked the basic trouble codes with a needle multimeter- says it fine with everything plugged in.
I'm at my wit's end.
Here's my question:
From what I've read, a 2.0l manifold should bolt up to this 2.4L. If I get one of those and throw a weber on it, will it work? Will the existing computer advance the spark, etc.? I am really sick of this fuel injection system.
Any help/wisdom would be great appreciated.
Thanks
