Looking for a recommedation for a stronger clutch.
I replaced the clutch back in 2019 but it is beginning to slip so I need to replaced it again. The vehicle is a 1984 Dodge Ram 50 with a 4D56-T and four wheel drive. When I replaced the clutch before I just ordered a basic clutch from Amazon. If someone could suggest a good clutch I would appreciate it. I also see those clutches with the copper looking pads. Are those any better than the regular lining material? Some of those have a solid hub instead of a spring loaded hub. I am thinking that those might be more likely to shudder. Anyway any suggestions would be appreciated. Then I will have some transmission questions. Mine is starting to whine a bit.
Thanks, Rick.
