Hi all,
I have an 87 with 4wd and the 2.6. I see that belltech makes a lowering spring kit. Just curious if anyone has fit that onto their 4wd or if it would only work with a 2wd.
Thanks!
Hi all,
Thanks!
The 4x4 uses torsion bars up front. I think it'll bottom out if you crank the torsion bars down (might get 1-2" of adjustment at most...) The front torsion bar will probably be tired or out of adjustment already. Rear end is leaf spring so it would use blocks to lower it. Not my truck, but I think it would be ill advised to try to lower your 4x4.
