86 mighty max wont start? Carb parts identification and removal tips
Hi, i'm getting fuel to the carb, but i don't believe i'm getting it through it. I'm having a hard time removing the upper half of the carb to get to the bowl. couple questions... what is the switch held on by the two brass plates and screws in the lower right corner of this picture ( stole this picture from a different thread).
http://www.mightyram50.net/vbulletin...id=26050&stc=1
Also, just to double check. I should be able see gas spraying into the valve body when i turn it over, from the brass jet above the butterfly valve on the left correct?
https://lh3.googleusercontent.com/HQ...-no?authuser=0
Also any tips on how to remove the upper half? i see the 4 main head bolts, and the two screws in the valve body. not finding much else and its still solid after removing those. Thanks you
