no start after installing injectors 2,3L
hello!
i tried a search but couldn't find anything yet.
i just had my injectors rebuilt and am having no start after installing them.
in a search of other forums, it seems this is fairly common and just need more cranking.
i attempted to push all the fuel to the IP already and reattached all electrical components after unplugging the IP to do compression tests. the injectors look right and seem to be making a seal with the new washers.
i've got the battery on a charger, in case i wore it down with the compression test.
i am only cranking about 10 seconds at a time, and letting the starter cool down after each attempt.
am i being too shy with my crank time?
thanks all
