1992 Mighty Max Restoration
Hi, I'm new to this forum. I purchased a 1992 Mighty Max 3.0L (6G72 engine) I'm currently restoring. I needed something for hunting/camping/fishing and can't afford to buy a new truck. I put a new LUK clutch in it including pilot and throwout bearing, fuel pump plus restored the tank, all new top end gaskets, new camshaft seals, valve guide seals, new timing belt, waterpump, radiator, all new coolant lines, TPS, IAC valve, distributor, pretty much everything is brand new. The truck has 177K on it. But, I have run into a couple of problems. The MAF was missing as well as part of the harness. I was able to purchase a used 055 MAF of Ebay as well as the pigtail out of a 3000GT. The problem is I need to match up the color coded wiring, I have had a terrible time finding diagrams/schematics. Apparently alot of these Mitsubishi's are wired a little different. The only common wires I have found are the green/Lime, Pink, white/black. My second issue is my shifter is really loose, I took it apart and found the plastic bushing that mates between the tranny and shifter was grennaded. I beleive it is a V5M21/KM145 I'm having a horrible time trying to find a part# I would appreciate any help, Thanks
