Two broken bolts, bottom of water pump
So I had a leak from my water pump on a 1991 Mighty Max with a 2.4L engine and, much to my surprise, it was not the weep hole that it was coming from. Instead, one of the bolts had sheared. While taking it down, a second one sheared, so I now have two studs stuck in the block, one roughly flush and the other about 1/16 to 1/8 of an inch above the surface.
So far, I have tried PB Blaster, penetrating oil, EasyOuts, and am now waiting for my drill to charge so I can try a larger extractor. Anyone have any suggestions or tips to make this process less frustrating? Thanks!
