Need help with weber carb
I Put a 32/36 Weber with a electric choke on my montero. It works fine when its warmed up and on the road, but its hard to get driving because the carburetor doesn't want to idle in the cold. I've adjusted the idle speed to 1 1/2 turns, and not over like it says in the paper work. And the choke plates are closed when cold. Looked for vacuum leaks around the intake and tested for vacuum and both were good. The screw behind the choke doesn't step down the rpm like it should, kinda feel like it doesn't work even though I made sure its touching the cam step down thing. Not sure what it is:confused:, any help is appreciated, thanks for reading.
