1990 mighty max 2.4l starts but won't idle help
My 90 mighty max 2.4l 5speed starts and will idlefor a few then die I just replaced spark plugs (new plug wire replaced a month ago) new ignition coil, new distributor cap and crank shaft sensor, and new starter. I also have my fuel pump straight wired with a toggle switch usually when I started it I would have to flip the switch then turn the key but since I had to replace those parts it won't start with switch on but when I turn it off it starts then I have to quickly turn it back on to stay idled then it will idle for a minute and die
