Speedometer problems after cluster swap.
Hey guys been a while. Swapped over my 2nd to the sport cluster, everything works great except for the speedometer. The speedometer slowly creeps up at the same steady speed no matter what the vehicle speed actually is. Also when i stop or slow down the speedometer needle just stays at the highest point until the truck is turned off. After i turn the truck off the needle will slowly creep back down to the default position.
**After swapping the cluster the speedo cable would barely reach and when reinstalling the cluster it was a very tight fit.**
Has anyone had this problem? Do you think my cable is just bound up some way causing it to lag like this?
