1990 mm, 2.4L. Truck was running great, no misfires or shakes. This post kind of has two questions. It was running great, and then it wouldn't rev. It would get to maybe 2000rpm and back down, kind of like it would at redline. But at 2k. Did a little digging, and found that if I unplug the ISC motor sensor, it revs perfect. Drove it like that for a day or so. Had it idling, about to charge the a/c, and it died. Hit the starter, and it runs for about 3 seconds, badly, and dies. Try a few more times, and if it starts, it does that same thing. It has spark, and the fuel pump is running. Timing was just done, and it has perfect compression. If I spray carb cleaner through the intake, it runs perfect. The second I stop, it dies. Another symptom of no fuel that it has is that if you try revving it while it is attempting to run on it's own, dies instantly. My guess is that the injectors aren't firing. Is there a fuse for this? The interior panel only shows accessories, and the fuse link box only has ign, head, and fuse b. Any ideas?
