Intermittent Charging issue - at whits end
So I have a 91 Mighty Max with the 4G64, 5spd manual, 2wd. Amazing little truck. Over the last few months I have had the most pain in the ass issue. The vehicle, from a cold start, will charge the battery like normal at 14.5v. I can get away with 20 min or so drives without issue, but either when I turn my headlights on or I drive for about 30 mins, it will stop charging the battery. It will sit at around 12.8v without accessories, and then when accessories or lights are turned on, it will slowly drain until dead.Things I have done:-Replaced alternator-Cleaned up all grounds, verified continuity and resistance at all ground points-Checked all fused links I honestly have no idea what the issue is. My current thoughts is that it may have something to do with the ECU if that is involved in the voltage regulation, but I can't even determine if it does. I know there are three wires from the alternator, the bat+ connection obviously, a white wire I think is voltage sense, and a blue wire. I think the blue wire might go to the battery light on the dash, my manual says "voltage combinator" and then "gauge cluster" but I am not sure if the voltage combinator is part of the ECU or even something that would cause this issue.So here is my questions1. Does anyone here have an idea what might be going on? Is there a common issue that I should look into?2. Is there a hacky way to fix this? Either tying the blue wire high or tying it low if it is part of the ECU? I don't want to replace or repair the ECU.3. If none of the above are true, is there an easy way to convert this vehicle to a 1-wire alternator? Anything that will just bolt up without modifying belts and brackets and stuff?Thanks!
