Balance Shaft Elimination
Hey everyone!,
I got myself a 1987 Mighty Max with the 2.6L recently and need to fix an engine issue. The previous owner at some point broke the timing chain tensioner which in turn tore the teeth off of the main drive for the oil pump and now the balance shaft of the back of the oil pump is shot as is the bearing hole in the motor. I have seen there are elimination kits, however I am not sure which one to get. I have read that the cheaper ones can cause issues down the road. Any help is appreciated!
