I’m tuning my 4G64 and replacing gaskets. Can anyone tell me if my engine has head studs or bolts?
My 1990 4G64 has female hex head bolts, if I remember they're 10mm. I don't know if they changed that for '92.
Be sure to take precautions to not drop lifters from the assembly when you remove them. Here's a helpful hint:
http://www.mightyram50.net/vbulletin...ll=1#post26624
Head bolts can be seen, next=to=last photo, right-hand side of photo.
http://www.mightyram50.net/vbulletin...ll=1#post26317
Mitsubishi used head bolts. Be sure you know what type you will need as there are different length bolts with different diameter shoulders on them.
Should I replace them with new bolts or switch to studs and nuts?
4g64 head bolts are reusable, no need for new ones.
