1st gen manual windows
The passenger window seems to be out of alignment as it pops outward if I crank it all the way down. Then when I roll it up it lifts the beltline. Is there some adjustment? I cannot find any.
My driver side cranks hard. I took it out and greased it and it rolls easy out but when it is in the window which has to be pulled over to attach seems to be the reason why its is hard. I expect new glass channel will help but again it seems like that alignment is wrong. Putting teh glass back on to the crank I had to pull it over an inch or so to get the screw started. That seems to be part of why it cranks so hard.
As to the problem with the passenger window I have determined that it is going down lower than the driver window does. On the driver side when fully cranked down the top of the window does not go below the inner felt of the belt line. The passenger window does. Is this adjustable?
