Need help I am new here I have a 1994 mits mighty max no power to fuel pump or relay any help will be very much appreciated I am at my wits end
Hi, Jerry, and welcome to the forum -
you DID check the fuse, yes? As yours is a '94, and a 6G72, I'm not familiar enough to suggest anything else...but someone here will come along and offer better advice. However, with cars (and these trucks), always look for the simplest answers, first :)
Again, welcome to the forum.
Have not been able to find a fuse but did check all fuses and have power to all both sides, need to find out where power comes from for relay ign, coil fuse box or somewhere else
check your ECM - capacitors fail in the box and can cause the problem you describe. It is on the passengers kick panel up near the dash.
If that is the case it intel’s changing out the computer right
I believe that people repair the computer board pretty regularly, but I'm a carburetor guy. My carter fuel pump failed internally tonight. 400 dollar tow home :thumbdown:
Yikes! An expensive fuel pump fail on a couple of fronts. I had a Carter once - it coughed metal and blocked up a fuel strainer. Too expensive for a fuel pump to die like that so I never got another one (and it was hell noisy too)
That's why I have AAA premier - you get 3 100 mile and 1 200 mile tow per year...
