Rear interior panel
Today I made up a ply panel for behind the seats. After drilling holes along the top edge I realised I have nowhere on the bottom to mount to, the rear floor seam of my cab has all been replaced.
Could anyone show me what should be there? My parts book shows 4 points along the bottom edge
There are a couple of supports that are spot welded to the bottom of the rear cab panel. The top part of the trim panel is held in place with 5 plastic mushroom lugs that run along the lower edge of the cab brace under the window.
Are they just C shaped bits?
They're a straight strip of metal with a step bent into the centre of them, spot welded to the rear panel ribs. 2 either side of the trans tunnel about 4-5 cm off the floor. They look like they only space the trim panel away from the rear of the cab enough to match the inner ledge of the cab brace under the window.
Cool I think I have the remains of some old spot welds there. I'll figure something out
