I Rebuilt a motor 1985 2.6L, and have got to the point of no spark at the plugs and weak yellow spark to the distributor off the main coil wire while grounded to the block and cranking. Have installed a new cap and rotor and will try a new coil today. I don't think its coil or distributor issues i had two of each known to work that I tried and still the same problem, but I'm making 100% sure as i go through the process of eliminating issues, and have tried a different battery, cap, rotor, and will try a new coil today. Any other suggestions?
Could this have something to do with adding a electric fuel pump and the oil pressure shut off switch? I don't think so based on having power to the coil going into the distributor but just weak. Any help would be appreciated before I have to get a mechanic.
