New to the site!
Hi, I'm on my third Ram 50. I've installed a Kubota diesel in it and am searching for a way to change the diff. ratio. From my meager calculations I would like to have 3.25 to 3.5 to 1 if possible. All suggestions welcome. Thanks for this site, I'm sure I will enjoy it!
Hey, you might have some luck with a Mitsubishi scorpion diff. They had 3.3:1 on the 10 bolt diffs and 3.5:1 on the 8bolt (weaker) ge auto
The 10 bolt diffs are the same as the truck so should swap in alright, or just the head of you need
Hi and welcome to mightyram. You can use a Gen 1 Montero/Pajero/Shogun etc rear diff. You can also use a Gen 2 truck diff and will more than likely be easier to find and swap in. A post in another thread, same topic - http://www.mightyram50.net/vbulletin...ll=1#post59224
