been real cold over the last month and one thing i have noticed is till my auto transmission gets warmed up the speedometer cable will chatter and the needle will fluctuate like crazy once the trans is warmed up everything is fine. so i,m thinking that maybe it needs to be lube i need some pointers on where to start and what to use as a lube like do i use white lithium grease? do i need to pull the dash in order to get to the back of the panel? is there a quick fix? lets start the feed back:)
1988 dodge ram sport automatic trans 2.6l
