Cold start getting better
I've been able to start the truck now 2 times with out starting fluid but it takes a while. I find that if I turn the key to on and then of several times and then with out touching the gas pedal it will start and then die after 10 or 20 seconds. If I keep doing this for 3 or 4 minutes it will eventually start. once warmed up it starts no problem. Wondering if it is a fuel pressure issue that I loose it after it sits. I read on one post that the pump doesn't run in the on position but does in the start until the engine starts and then the ecm will kick in and run the relay. Once it's running everything seems to be as it should.
