I'm considering a power steering swap, does anyone have a pic of a first gen engine bay sans engine with the lines in place so I can see them routed?
Geronimo's gallery pics have a shot of the power steering lines with the motor in that should show most of what you need.
No - mine runs on the firewall above the motor - the 2 lines you see on the firewall are the power steering lines. If the A/C lines were back on, there would be a third line above the other 2.
Is the line meant to be set up as a heat exchanger? It would explain why it is designed to face forward into air flow.
