Valve Seals & Exhaust Valve Guides 87 Ram 50 Question
1987 Dodge Ram 50 Blowing smoke mostly on startup and after idling.
other than that its running fine.
It seems to be dripping oil into the exhaust part of the head. Which I figured out after replacing exhaust header gasket and after breaking it in and going back to tighten it up found streaks of oil coming out of loosened gasket.
So I plan to replace
The Valve Seals
and replace the 4 Jet valve O-rings while I am at it.
but my question is
1. do the Exhaust Valve guides generally need replaced or wear out or only replace if damaged?
Should I? Waste of Time & Money Normally or probably big improvement?
2. Anything else I should consider replacing at the same time?
Thanks For any help
steve
