Hello all I am looking for a new/used grille for my 84 Dodge D50 Royal it has the dual headlight setup any help would be great
and i am also looking for new window seals and for both doors
Hi and welcome to mightyram. A member spotted a new one in the back of a truck bed - try this:
http://www.mightyram50.net/vbulletin...48-84-86-Grill
Are you looking for windshield and door glass seals? Other trucks' door glass scraper rubbers will fit (earlier B series Mazda/Ford - added bonus is they use compatible plastic clips instead of the metal ones) Windscreen rubbers are available new.
I was talking to this dealer when I found a used one for $50 a couple hours north. I have no idea if this dealer still has them since I saved this link last fall but the MB part number and partslink number is there. They are new. http://www.nationalautobody.com/cata...oducts_id=4732
contact Mike Warme on here for the door window fuzzies and wipers, and the door gaskets. Steele rubber also sells the door gaskets, but they are now china made and may not be good fitting.
If by dual headlights you mean the 6x7 two total headlights I have a grill
See your post on other page where I left you info on parts. or visit http://car-part.com
Also, all you need are the headlight buckets 4 the headlight system to work on a 2 headlight truck. I changed my front grill on Mighty Max from a 2 headlight to 4 headlight system some time ago. So, you can say I have the only Mighty max 4 headlight grill around. :lmao:
