Will a 2g mm fuel tank and pump work in a 1g?
So i have been thinking about what to do with the fuel pump for my 4g63 build and cost vs performance. Obviously you can run an aftermarket pump but could you drop a 2g fuel tank and fuel pump in it? I mean is there a difference in the tanks they look very similar? Will they bolt up, and how about the filler neck location is it close? would you be able to use the factory fuel line or will you need to run a new pressure line to the engine bay? it looks like factory fuel pressure on the 4g63t is like 38psi which I believe is close to the pump on a v6 mighty max or a 4g64 one right?
Figured i would ask before i tried to source one for cheap.
