Hi, Ted here from Sacramento. New to me, 95 mighty max, 5 speed 2.4 cyl.
I've been looking around the forum, good information here. Thanks for your hard work guys. I've since added a used shell.
Welcome aboard......lets see it with the shell, please.
The shell is pretty scratched up but it was cheap.
Attachment 18817
I'm told I'm the third owner. So far I had the steering gear box replaced, pittman arm, and idler arm. New tires (Hankook). It was running a little rough at idle. I replaced the plug wires, rotor, and rotor cap. Previous owner had Bosh plugs, I replaced with NGK. Also ran some Lucas in the tank to clean the injectors (if that stuff actually works).
I dunno, seems to be running better. 2.4 engine I think. 5 Speed, has a plastic bed liner that's in good shape...do I want to replace it with rhino?
I wouldn't unless it's damaging your bed when you haul stuff. I have a thick rubber matte in mine that came with the truck. Has the same impressions that the bed does on the deck, just not a flat rubber pad.
