I have been doing very regular oil changes, but should I keep an eye out for zerk fittings for grease. Or what are the procedures for grease ? Thanks Gs.
You don't need to service the zerk fittings because they should have a protective boot on them. I greased the factory ball joints on my truck with the original jerk fittings and they still worked. Although the ball joint has seen better days. I replaced the ball joint, but I recommend keeping the zerk fitting.
Oops it's been a long day. Completely misunderstood your question. Just grease your suspension with good suspension grease. Not much to it. Just be careful not to pop your boot by over filling it. The manual should tell you where the grease points are located.
