flooding no-start issue, hot-start issue
Hey guys, my 92 Ram 50 2.4 RWD truck I've gotten going here since a timing belt replace.. All seems pretty good for the most part performing as it should, besides steering loose on center and brakes grabby on one wheel more- could use service.
..except for a trouble starting issue sometimes, I know it's flooding out when this happens and cylinders won't fire, I smell the gas bad. Usually after the engine has been started and is slightly warm then shut off and tried to start again. Sometimes even when trying the first time on a cold engine.
I've tried no-throttle and max-throttle on the gas pedal to try and get it going with little luck. Usually best to repeatedly stab gas pedal when its barely coughing and wants to start.. before it clears out a real rich mixture and begins to run normally.
Any advice? I just cleaned fuel injectors and flushed fuel system. Could it be fuel pressure regulator problem?
