1980 Sport -Farm Rescue, Need help!
		I wrote a long nice post and when i hit post it deleted it because it auto signed me out.  So now you get the fast half ass version lol..
I was given a free truck, 191 original miles, auto trans.    The truck is ugly as all hell, a bit of cancer everywhere.  Cab forward and frame seem good though.  Was a old farm truck that sat for 10 years in a field.  I want to use as a cool retro little beater to haul things in.   Its runs, turns on but the carb had issues.  I took off to clean, someone had taken off before and could see old red rtv on the gasket.
I think it was a vac leak on carb gasket between mani, also the egr was seized up mid way when i looked.  I also replaced the secondary vac chamber with a spring to open at 1/2 throttle regardless of vac.
I believe the screws on the car, all 4-5 i see may have been tampered with.   I cant find a manual PDF or diagram for my 1980 carb.  The one i found seems to have the screws in a different spot...?     Can anyone help?
I need the factory carb assembly screw twist count.   So I can reset the carb back to its original settings to adjust from there.
Also what all emissions can you delete?  I dont need to pass smog in my state, and if i can simplify it it would be easier to find issues when they come up.  Whats required to run the engine, the less vac lines the better.
http://i1126.photobucket.com/albums/...ps07pusps9.jpg
http://i1126.photobucket.com/albums/...psfoky19zd.jpg
http://i1126.photobucket.com/albums/...ps10wduvhs.jpg
http://i1126.photobucket.com/albums/...psspmxra2n.jpg
