fuel compression & spark, no start..
Hey guys! I've got a 92 Ram 50 2.4L, had a broken timing belt and has been off the road over 2 years.
Replaced the timing and balance shaft belts, got all the marks right-on. Cranking the engine over now, it has compression we measured (between 90 and 120 all).
It will not run, at first it wanted to pop one time but then never fired since. Backfired once. It has spark.. was suspicious distributor may be 180 degrees off, tried it both ways and still nothing. Fuel tank was drained, and line off the fuel rail the bad gas was flushed out of the main lines.
So stumped. With compression, and spark (tested in multiple positions), and with starter fluid (should fire even if fuel injectors were clogged).. it should fire over but it won't at all! New spark plugs.
and help?
