Used Weber carb -- what to look out for?
Hello:
I am considering buying a used Weber carb. It's currently mounted on a 2.0 mighty max, still using a mechanical pump. Owner says it is an electric choke (what I need for my G54B), but doesn't know exactly what the carb model it is. My questions are as follow:
- I know BradMPH posted about authentic Weber castings here. Is carb's model model or carb's serial number stamped on it? If it's a serial number, then what's the easy way to tell the model?
- Can the carb be damaged being run off of a mechanical pump (over-pressurized)?
- If there is a way to fire up the engine the carb is on, is there anything I can do to test it out? How about if I can drive? I just don't have any point of reference as to how it should feel or how to check the typical weak spots.
- Anything else I should looking out for?
Thanks in advance for your help!
