I'm in the process of bleeding my brakes, but I am a little confused, do you bleed the rear left wheel cylinder? I just installed a new wheel cylinder and it came with a bleeder valve, but when I installed it, I had to remove the bleeder valve to connect the two hoses. The rear right wheel cylinder only had one hose, so the bleeder valve stayed on that one.
Truck is a 1988 MITSUBISHI MIGHTY MAX, 4X4.
