help!!!!! how do you tell if the timing chain needs to be changed?
88 dodge ram 50 sport 2.6l 127 k miles on it.
the last few days whenever i start the truck and it's sitting there in idle no noise but when i give it a little gas i,m getting clatter from the front of the engine.
sounds like it might be either from the water pump area or near the power steering pump.
once it warms up when i start down the road no noise/ how can i check to see if it,s the timing chain is going out?
or is it the water pump?
i don't want to run it till i get some advise on here. i really don't want to take it to the shop it will probably cost me an arm and leg.
check out vid
https://youtu.be/eXTeLSOW7us
