[HELP] ECM or TPS maybe??
1991 Max 2.4L 2WD 4G64
OK hey guys after putting my first tank of fresh gas in my Max that was sitting for 3 years I'ts developed a engine miss. Now before we go and blame the gas because that's where I started as well I tried a tank of HEET to eliminate water and have ran it down to almost fumes and the problem persists. Second Full tank of gas still does it, and the third tank as well. I am also ruling out a FILTER/Pump issue because when I get on it the truck runs fine.
The issue I'm having is it misses and lurches when I'm just barely on the throttle trying to hold a constant speed. Its worse at lower RPM's and in Lower Gears but its all speed ranges. This truck was over heated by the previous owner and I just had the head redone and it starts first crank always. The timing is good and its got a new Cap, Rotor, Plugs, and O2 Sensor (I changed these out when we did the head).
So knowing this truck came from Utah and been in that desert heat, Its been over heated, and its sat for 3+ years here in the Midwest, I'm leaning toward something in the electrical causing my issue. My first two things that when I search that come closest is the ECM or TPS. Give me some advice on how to root out which is the culprit or even what may be the culprit. Both these parts are ridiculously expensive at a parts store so I'm going to most likely have to online or buy used. Is there something I'm missing that I haven't thought of or should check. Help me out!
